[FOR SALE] 69 Dart Swinger
Wizard
Dillsburg, PA
Would like to possibly sell whole car what's left of it minus the 340 engine/trans that was in it. The whole rear is gone already. Rest of inside car interior is there if its not busted up from the tree or pole it hit. Steering wheel completely bent and broken backwards. Probably hit at 85 or 100 mph. Don't know the story on it. Will sell just the whole bumper/fenders part as it is broken away from cowl if someone wants it for a conversation piece minus the usable parts attached. Everything else up for grabs unless someone offers for the whole car.
Horn-$5.00
Lower control arms $35.00 ea
I'm interested in the front bench if it's complete & the frame isn't rotted out. Depending on the cost of course as I would needed shipped to 98230 blaine Wash. Your inbox is full, send me a PM if you like. Thanks
PM sent on price on bench
Wizard
I'm looking for the 2 small chrome knobs on the heater and defroster controls if you have them.
Looking for this piece, the bottom bracket piece that connects the cross brace bars to the floor.
I am cutting up the car. Will be getting to the bench and rear seats. You have a e-mail I can send pics to then?
What are the part numbers on the leaf springs and how much for them?
I did not start cutting up car yet. Working on it though.
Did you get the part numbers on the springs yet, I would like to pick them up at Carlisle Friday or Sat if they are the right ones.
Ok, I will work on it this weekend. Ran out of oxygen with torch. will get the numbers for you
I got the car up in the air now to look at the springs. I forget. Where are the part numbers on the springs located? Will get you some pics
what does the dashboard look like. 4speed car? need the 4 speed hump. need front seat tracks. also looking for clutch and brake petal assembly.
Dash is there but I don't know if it is salvable. This was a automatic car. I don't have any 4 speed humps. I am going to sell the seats but don't want to break them up. I don't have a clutch or brake pedal assembly.
How are the lower c-pillars, from the seam down to about where the vinyl top trim would be located? I can also use the portion of the dutchman from the window ledge to again, where the vinyl top would end. The top on mine went bad and left some holes in those areas.
Geez. I just saw zawed the c pillars. Dutchman I saved and is okay. Trying to get back window out so was saw zawing around the whole back part of roof, have to get torch on inside to cut. I will get some pics of the c pillars and other pics
Let me know if you can use anything. I saw zawed. Let me know before I torch and saw zaw anything else?
