69 dart wiring
bigblockbill
Member
canada
hey, can someone please show me a picture of the harness for the turn signals off the steering column. I had all the wiring in my dart cut out and I'm not too sure what is what. I'm putting in speed wire and I need to run the factory lighting(4 ways signals brake lights) in order to have it street legal.
about the build:
pro street 69 dart swinger
470 stroker pump gas
stage 6 heads
indy tunnel ram
440 crank
750hp,650 tq
thanks for the help!
Sounds like you need diagrams/ shop manual. Run over to MyMopar
I can't post these because of the stupid *** "improved" software which will attempt to display the thing instead of just show the link
Here is aftermarket diagrams. These are sometimes easier to follow BUT ARE often not as detailed and don't properly show factory connectors
MyMopar - Mopar Forums & Information - Mopar Wiring Diagrams 1966 to 1971
Here is the "mother lode" these are free factory service manuals
MyMopar - Mopar Forums & Information - Service Manuals
BEAR IN MIND that through those years there is a mistake involving (I think) the start wire vs the horn wire going through the bulkhead
Do you have the hazard switch? That should be separate, dash mounted in 69. "How it works" It is a 4 terminal switch, all terminals separate when off, and all terminals connected when "hazard" You feed power to the hazard flasher, then feed to one terminal of the switch.
A second terminal of the switch hooks to the brake light switch output branch in before it feeds into the signal switch.
The third and fourth terminals feed to the front left and front right signal wires coming out of the TS switch.
INTO the TS switch you have .......TS flasher going in........and switched brake light power going in
Coming OUT you have left front, right front, left rear, and right rear. The two rear are connected together when centered, and are your brake lights.
