[WANTED] 69 Formula S Tail Panel Emblem
they list it, are you ready for this? hold tight!
FORMULA S MEDALLION 1969 BARRACUDA TRUNK PANEL EA$250.00
Ouch!!
MR-69cforms - laysons. $98.00 - The Black may be a bit to glossy but a nice piece IMO.
I see the website is having it's issues.....sorry about that.
If you click on the link for "Part Number Search" just above where it says "Tailpanel Emblems"(between "Catagory Search" and "Keyword Search") and enter the part#, the part description will come up. Next to the part# itself, there is a little camera icon you can click on to bring up a picture of the emblem.
That's how I found it..
A tip to install it is to get a snap repair kit like attached and use the drift to peen the posts over. They are hollow like the snaps or tubular rivets are and the tool is designed to roll the edges over. Just support the badge on a hard non marring surface and tap away.
I had a reproduction emblem some years ago and when I tried to peen over the studs they started to push thru the emblem itself. I ended up having to buy a second one which I epoxied on.
Thanks to all for your responses. I did find through Rick's link to Layson's. Wow! pricey, this will have to go on my gift list for the family. Birthday in May.
Thanks again.
That bites!
Guess I had better luck! Thought about using the pal nuts that are used on the console plates as well but light tapping got mine done.
