[SOLD] 69 Plymouth Valiant
Bigdummy
Not a Nova
Cleburne,Tx
CAR IS LOCATED IN 76031.26,000 OBO!
Has 15 miles on new Engine.I took it for a ride and tried to run the valves and due to health I busted my knuckles and couldn't do it.I have no one to help so I'm shipping it.
470 cid
72 400 block
Main cap gurdle
Mopar steel crank
6.535 H Beam rods with ARP 2000
Manley pistons
11.2 to 1 compression
Million 7qt pan
Trick flow 240 heads no port work
PRW 1.7 Rocker Arms
Can't remember the pushrods
Comp cams 578/582 248/254@.050 Extreme roller
Performer Rpm
Nitrous Express 100 shot loaded,rings gapped for 150/175.Never filled the bottle.
930 cfm E 85 carb with spec sheet
Aerospace 300gph pump and filter
Tank in the trunk
2 batteries
Tti headers
Spin tech 6000 mufflers.
100amp alternator
Big radiator and fans
Gerst suspention.Needs the spanner nuts tightened.I can't do it.
Wilwood street Brakes
Turbo action converter and Manuel valve body 727
8 3/4. 3.73 ratio
Split monos
Assassin Bars
Billet specialities
295/50/15 Mt drag radials
Front are Mt but nees new tires.
6 point roll bar.Removeable door bars that fit tight.
I had took it a car show but that was trailered.
It has a sir flow Guage but never hooked it to the exhaust.
Paint is fair.It has a bubble in the rt wheel opening.
When I can I'm a long haul truck driver and am gone till December 22nd and will be home to show the car till the 2nd week of January.
