Trying to get the gas gauge working in my bee it hasn't worked since I've owned it. First I checked the gauge by grounding the sending unit wire to the chassis
then turned on the ignition switch and the gauge goes to full. So I dropped the tank and removed the sending unit to test and it is bad upon further inspection
of the sending unit the resistor was burnt. I got a new sending unit to install and decided to test its accuracy before installing it in the tank. I first check the resistor value with the fluke meter, in the empty position had 78.8 ohms and full
was 8.7 ohms. I then got under the car and grounded the new sender to the chassis and hooked up the sending unit wire to see what the gauge read at empty and full. Empty gave no deflection of the gauge and full only moved the gauge to E:violent1: so ice checked the voltage to ground at the sending unit wire at the tank and had 11.6 volts and voltage at the battery was 12.3 I verified the ground was good at the tank. So what gives! This has me scratching
my head as to what else could be wrong. Does that voltage at the tank seem normal? Any ideas would be really appreciated.
