THE DART Member Joined Apr 17, 2013 Messages 24 Reaction score 0 Location Ontario May 27, 2013 #1 My Dart has recently has an issue when trying to get it out of reverse, it takes a few minutes of moving the shifter around, depressing the clutch, and finally it will pop out, anyone had this issue before??:?
Rocky_JS 'cuda Joined Feb 27, 2011 Messages 4,187 Reaction score 347 Location Highland Maryland May 27, 2013 #2 probably in need of a linkage adjustment
THE DART Member Joined Apr 17, 2013 Messages 24 Reaction score 0 Location Ontario May 27, 2013 #3 Where do you make that adjustment, i guess it gets loose over time? Thank you
Rocky_JS 'cuda Joined Feb 27, 2011 Messages 4,187 Reaction score 347 Location Highland Maryland May 27, 2013 #4 if it were close it could have worn/loose and becomes tough to shift [ame]http://www.hurst-shifters.com/wp-content/uploads/3737437.pdf[/ame]
THE DART Member Joined Apr 17, 2013 Messages 24 Reaction score 0 Location Ontario May 27, 2013 #5 thanks very much for the attachment , will have a look.
TrailBeast AKA Mopars4us on Youtube Joined Mar 11, 2011 Messages 22,475 Reaction score 12,004 Location Arizona May 27, 2013 #6 Is it hard to get into or out of any other gears? If not it's probably just the linkage adjustment needed.
THE DART Member Joined Apr 17, 2013 Messages 24 Reaction score 0 Location Ontario May 27, 2013 #7 No only gets stuck in reverse, i hope it is the linkage Thanks
cudavert DARTAHOLIC Joined Apr 16, 2009 Messages 2,867 Reaction score 517 Location Hesperia, CA May 27, 2013 #8 Yup, shifter linkage, I'll bet......mine used to do the same thing.
swinger340 Well-Known Member Joined Jul 25, 2010 Messages 2,273 Reaction score 61 Location Maine May 27, 2013 #9 Mine did the same before tightening everything up and adjusting linkage
THE DART Member Joined Apr 17, 2013 Messages 24 Reaction score 0 Location Ontario May 28, 2013 #10 OK will try adjusting, thanks very much everyone.
