These are the part # I used to patch my lower quarter,from Classic Industries, AMD parts. 70-76 A body trunk extension #MM1424, 72-76 A body quarter patch panel #MM1459. Worked out great. On the trunk extension you will have to bend up the back lip to slide into place under tail light then bend back down. The quarter patch works great if you don't have to go above the lower body line. And you will have to trim off a little in the wheel well. Because the new panel has more lip on it. Hope this helps. Dave...
