69 valiant converting to disc front brakes (recommendation)
sketch
Burleson, Texas
So i am converting my 69 to disc front brakes. The car has original 13 inch x 4 pattern wheels on it. I have been told that 13s won't work with a conversion kit. I am planning on using an early (pre 72) kit. I need a recommendation what 14 inch wheels and tires will work to keep the original bolt pattern.
I will also take suggestions please on the disc kit.
If you stick to oem parts you cant go wrong.
Kelsey Hayes 4 piston and all associated parts will be bolt on.
Other kits will bolt on but when it comes to getting replacement parts down the road you will have to remember what car to use as a call out, just complicates things.
As for wheels most any 14 inch with the correct back spacing will work. But stock OEM or after market oem wheels will work.
Stock or run a wilwood kit. They make one that will take smaller wheels. I run mine with 15's though.
yes. please send pics
Big bolt pattern
