They will bolt on and work. Other than the differences in the headlight area OMM mentioned, '69 uses a rectangular side reflector, '70-1 uses a rectangular light, they're a different size, and they're in a slightly different spot. '70-2 use an extra tab for the hood latch/grille support crossmember (easy to make or remove). The '67-8 and '72-6 fenders bolt on too, but, with the same side marker, possible headlight, and various other molding differences.
