mickey
Anybody try using the 318 shumacker mount on a 360 engine, i do know that the motor mount bosses on 318 eng compared to the 340/360 eng bosses are the difference(318 wider then 340/360), I am thinking that 318 schmacker motor mount which is wider, i would only have to use spacers to fill the void for these mounts to work on a 340/360 block. anybody try this,or comments would be great. thxs folks
These are spool mounts schumacker conversion 6cly to 318. You can order 6 cly to 318 Or 6 cly to 340/360.
