7 1/4 25 Spline Axle Diameter
RustyRatRod
Caput villa stultus
Georgia
I've searched with no results. Can someone tell me the diameter at the splines of a 7 1/4 25 spline axle? Thank you drive through.
1.029 at the final taper where the splines are hobbed onto the axle and the spline diameter is 1.131, give or take a few thousandths on the dial caliper.
A little wide right here trying to photograph and hold the calipers. But 1.029 at the step before the splines.
Thanks Garrett! So at the splines you got 1.131. I should have measured it before I assembled this one I JUST put under Vixen, but my stupid *** didn't think about it. Thank you!
