1WildRT
Just one more way these cars can be a PITA... But when everything is together & your out on the road the troubles are a distant memory...
i too have used this method with success.No need to pull stuff apart.
Remove the wheel. Put a few lug nuts on, hold a pry bar between, tap the end of the axle with your hand as you turn the pry bar.
Done.
