1. MikeD
    MikeD Well-Known Member
    172
    52
    Dec 16, 2004
    Nottingham, England
    Local Time:
    6:08 AM
    My 7-1/4 has quite a badly worn ring and pinion but i know where there's a better one very cheap but its 4 inch pcd and mine's 4.5, just wondered if my ends would swap over.
    Mike
  2. mvh
    mvh FABO Gold Member FABO Gold Member
    1,402
    181
    Dec 17, 2007
    Menlo Park, CA
    Local Time:
    10:08 PM
    "pcd"???
    Are you referring to wheel bolt pattern?
    I thought all 7-1/4 rears used small bolt pattern axles, on slant six cars even after 1973.
  3. Tooljunkie
    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
    9,616
    8064
    Jul 22, 2017
    Manitoba
    Local Time:
    12:08 AM
    Nope, i put a 7-1/4” in in saturday. it had big bolt pattern.
    Diffs with same axle length will interchange.
  4. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
    16,085
    4905
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    12:08 AM
    The big bolt patterns have 3inch tubes versus smaller on the 4s, requiring matching shock brackets and U-bolts. Not sure about springs.
  5. MikeD
    172
    52
    Dec 16, 2004
    Nottingham, England
    Local Time:
    6:08 AM
    The guy has all that stuff as well, i just want to know if i can swap my larger stud pattern parts, over to the other axle to avoid changing my draglites.
  6. AJ/FormS
    16,085
    4905
    Jan 19, 2014
    Local Time:
    12:08 AM
    Not by themselves, with no other changes
  7. Kern Dog
    Kern Dog Well-Known Member
    2,968
    2890
    May 23, 2010
    Granite bay CA
    Local Time:
    10:08 PM
    Sorry, this is not the case.
    All A-Body 7 1/4" axles used 2 1/2" axle housing tubes. The large bolt pattern versions were used in both Slant six and V8 models with front disc brakes.
    The U bolts were made longer for the 1967 and later models but the mounting plates are the same design from 1963-76.
  8. phatty67
    phatty67 Member
    10
    0
    May 16, 2018
    new hampshire
    Local Time:
    1:08 AM
    im working on a 67 cuda 273 with drum brakes all around it has a 9 bolt 7 1/4 27 spline and it has small bolt pattern. it was a restore a few years ago
