Bulldozer
free ice cream sandwiches
:sign3: i am 7 1/4 uneducated. i have never worked on or messed with a 7 1/4. someone i know is wanting to know if the splines on a big bolt pattern A body axle are the same as a small bolt pattern A body axle. will the axles directly swap over or do the spider gears have to be switched out with the axles. i cant seem to find any info anywhere. the rear end is a 2.91 open from a 74 A body.thanks in advance for your input.
