there seems to be a lot confusion with the 73 and 74 cars. some say the V8 dictated 7 1/4 BBP in 73+ , some say the disc brakes dictated 7 1/4 BBP in 73+. i heard of 6/ cars with disc brakes and BBP and ive heard of 318 cars with SBP. my original 74,000 mile 73 6/ car with drums all the way around is a 4" pattern. i am almost positive that the disc brakes could not be had in 4" pattern, but that wouldnt explain the 8 3/4 with front disc and a 4". from all ive read the A body 8 3/4 was a 4" pattern only and later went to a 8 1/4 BBP. i am just as confused as a lot of us. maybe someone can clarify this. im sure this has been brought up a dozen times. and..i dont think the A body 8 1/4 came with a 4" pattern. there needs to be a sticky chart outlining all A body rear ends, with their production runs and pattern sizes, along with a disc/drum breakdown of years and 4 to 4 1/2 pattern usage, and what dictated what.
to even further confuse things lolI had a 73 Swinger with Big Bolt Pattern 4 wheel drums...
I think maybe what happened is in 73-74 they made the change over to the larger bolt pattern. If there is a pish posh mix late 73 or in 74 it may be due to the fact they wanted to use up what they had on hand.
Just my thoughts.
Not unless someone installed a BBP set up on the car.
Drum brake A bodies were SBP. Jan 1, 1976 ALL cars were disc brake, thus LBP.
73 V8 cars got Disc as Std equipment, /6 cars it was an option until Jan 1, 1976.
8.25 = BBP 7.25 could be either SBP or BBP
x2not unless someone installed a bbp set up on the car.
Drum brake a bodies were sbp. Jan 1, 1976 all cars were disc brake, thus lbp.
73 v8 cars got disc as std equipment, /6 cars it was an option until jan 1, 1976.
8.25 = bbp 7.25 could be either sbp or bbp
Just one more point on this as an FYI.....the small bolt pattern 7 1/4 rears cannot be switched to large bolt pattern just by changing the axles to a pair from a large bolt pattern 7 1/4. I can't remember why off the top of my head.....I believe the innerds are different somehow...
Bearing size and axle shaft length.Just one more point on this as an FYI.....the small bolt pattern 7 1/4 rears cannot be switched to large bolt pattern just by changing the axles to a pair from a large bolt pattern 7 1/4. I can't remember why off the top of my head.....I believe the innerds are different somehow...
I'm not sure exactly what you're trying to say about this. The 7 1/4 axle shafts with the SBP all interchange from '63-76. The 7 1/4 axle shafts with the BBP all interchange from '73-6. The problem is when you try to put a BBP axle shaft into a SBP housing. They won't fit because of the bearing size and length of the axle shaft.The width difference was only on 9" drum rears. 9" drums only came on 7 1/4" rears and all were SBP
