Chuck Bushey
Active Member
I had a growl in the differential and pinpointed it to the front pinion bearing. Got a new bearing set and working to get them installed. Using the same pinion and ring gear. The pinion is marked as -0 so I assumed I didn't need any change in spacers. Specs say the pinion nut should be torqued to 240 ft-ibs and should have a preload drag of 15-25 in-lbs. With nut tight with wrench but not torqued I have 35 in-lbs of drag. Prior to disassembly I had about 10 in-lbs of drag. I'm afraid to try to torque to 240 ft-lbs concerned the pinion might not turn. Anyone have any comments / recommendations.
Happy 4th to you all!
