Use PB blaster ,and plenty of it, let it set over night, i didn't have a pinion yoke wrench, i used a large pipe wrench to hold pinion, then a breaker bar with a 4 foot pipe, and the warning about dont pull the car down on you is definately correct, i had mine on a kwik lift on all 4 tires and the car slid to the side and lucky the back quarter panel hit the side of the garage, or it would have tumbled on the floor and myself, best i remember the thing torques at 210 ft/lbs with a new crush sleeve, so the old one has rust and if it was torqued at proper spec you can then realize what it will take to break it loose. A large impact versus breaker bar and pipe is the safest if you have access to borrow or rent one
