[WANTED] 70 340 duster parts
1. Bench seat and rear set also belts set.
2. Front bumper and rear
3. Front windshield
4. 340 intake manifold late 69 year.
5. Engine wire harness.
You are better off purchasing the engine wiring harness from YearOne. M&H makes an OEM form fit and function harness, all connectors are the correct ones too. They are expensive, but you get what you pay for. I did not regret spending on mine. Safe from fires caused by bad harnesses.
To help on your bumper search, the front bumper is the same '69-71 Valiant. '72 will work too, but, has slots cut in it for the later bumper jack. The rear is the same from '67-9 Valiant, '70-1 Duster and Demon, and there again the '72 Duster and Demon with the jack slots.
