70 dart suspension setup drag racing
Mopar Racers Forum
  1. y26
    y26 Member
    18
    0
    May 21, 2015
    Crosby ND
    Local Time:
    12:00 PM
    Ive got a few questions on shock & caltrac setup on a sbm 420hp 1970 dart. It has mono leaf & qa1 adjustable shocks with caltracs in back, qa1 adjustable shocks in front. always ran footbrake and it felt like the whole car would just jump up when leaving off line. This year we put a powerglide trans and are leaving off a brake after adding a 9" rear. What setup should I start with on the shocks and caltracs this weekend?! Any help appreciated, Thanks!!
  2. y26
    y26 Member
    18
    0
    May 21, 2015
    Crosby ND
    Local Time:
    12:00 PM
    i forgot too add, the car also has subframe connectors
  3. Rocket
    Rocket FABO Gold Member FABO Gold Member
    2,459
    446
    Apr 22, 2005
    U.S.A.
    Local Time:
    6:00 PM
    There is a threading this site on how to adjust Caltrac suspension. Try using the search function. It had suggestions on setting initial preload.
  4. hangn0ut
    hangn0ut Well-Known Member
    747
    120
    Dec 3, 2012
    rialto.ca.
    Local Time:
    10:00 AM
    There is a sticky for Cal tracs on this forum. Near the top of the first page.
  5. AJ/FormS
    AJ/FormS 68 Formua-S fastback clone 367/A833/GVod/3.55s FABO Gold Member
    22,915
    9932
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    12:00 PM
    I have a similar 420 hp 68 Barracuda, and suffer from the 2plus /60fts with street suspension.And 325/50-15 DRs barely get it under 2seconds. Once you get it working, could you post up results? Maybe Ill bite the bullet and do something back there this year.
