340plot
the bushy bush
i have a 70 dart swinger that is a original plum crazy fc7 car. i have someone intrested in buying the whole front clip, but want to try and sell as a whole. i have perfect fender tag, and title for this car.
rust. it needs attention the the quarterrs near the wheel well lips, and lower quarters. both side rockers need patches, which i have the pieces out of parts car for them. the rust does not go under the car into the seam. just the outer area. around the lower rear glass, needs a patch, and i have the entire filler panel for that entire area, that goes with the car trunk needs no work. inners are all good. frame rails are great. it has the cutout for a hump, as someone had a four speed setup in it at one time. i have the piece that replace this metal. front clip is clean. grille is almost perfect. front lavance has a dent. dash is decent. pad is no good. have bench seat that goes with car. all glass is good. has 8.25 under it, and drum brakes up front. has a fiberglass rear bumper, but ill trade it for a metal one if you prefer.
this car is a good canidate for a redo. origionally a 318 car
car is located 30 minutes from martinsville international speedway in va.
1,000.00
1,000.00
