[WANTED] 70 Dart turn signal switch
str12-340
Vashon, WA
I am looking for a new turn signal switch for my 70 Dart, All the repops that are available now do not have the wheel at the end of the spring loaded piece that bears against the back of the steering wheel for the horn. I installed one of these and put dielectric grease on the tip and back of the steering wheel where it bears, but I can hear the damned thing scraping against the wheel and when I took it back apart it is scraping the copper off the wheel. I understand that Chrysler had correct ones until about 10 years ago so I am hoping to score one.
Used one with correct part numbers
Thanks, Joel! I just don't understand why the new repops are not made correctly
Chrysler might be the only brand that had a little roller contact there. Certainly costs more to make. @slantsixdan
Several years ago, I had a used switch from a 68 column that I was going to ship to a member in UK. It tested good with ohms meter. Before boxing it I decided to clean it a little with compressed air. That little spring was rusted, went to pieces, gone with the wind.
I have a 70' column for parts. Are you interested in a good used one or a minty N.O.S. one let me know and I will check this one for you.
Check ebay
Item Number: 372 848 052 867
70-77 OEM used 3488804
This one has the wheel
