A340
Passing and looking for good info.
Have stock 340-4bbl 4spd 391 gears Duster. Had original Carter AVS carb. After spending bucks and a lot of time, rebuilding, replacing, adjusting and tweaking I could not get it to idle and run right. I'm convinced that a 40 year old carb warps, melts, and breaks down after a long period of time.
I purchased the Thunder jet series #1826 650cfm AVS carb from Eldebrock. Right from the box to the manifold this thing fired right up, idled correctly when cold, and drove like a new car. The power was seat of the pants improved !! Only minor adjustments from the air/fuel mixture screws and idle adjustment were in order.
So those of you that have been fighting your carbs like I have, let me say that I wish i would have just spent the time and money first instead of messing around for a month or so on the old one. I'll keep it as is will go with the car if it is sold one day, as the car is number matching.
Now my question is this: Do I leave well enough alone or are there adjustments or tweaks I can do to this to make it even perform better?? Thanks
