In additon, generally:
Upper arms must be for modern disc brakes there are large and small ball joints depending on 73/ later disk, or drum setup
Lower arms are different in terms of anti roll bar. If there is none, the lower arms have no tabs to connect the anti-roll bar. The tabs are different for 72/ earlier LCA vs 73/ later LCA
tie rods and ends are pretty much interchangeable
In 73, the K member went to spool type motor mounts instead of "pillow" mounts, and the anti-roll bar goes THROUGH the hollow K from 73/ later vs, below it for 72/ earlier
Of course the /6 and V8 K members are different.
67 only K member has a "one year only" idler arm mount
