71 dart brake swap
First, do you want to keep the same rims and tires with the factory 5 on 4"?
If you do, then find a complete 67-72 disk brake donor car. Don't forget the proportioning valve and the master.
If you want the large bolt circle, use 1973-6 Duster or Dart sport as a donor car.
If you need this stuff I can help, There is a Mopar guy in CT for the large bolt parts and I have the small bolt parts.
I am in Hartford, CT
