[SOLD] 71 dart roller for sale
68cuda78
Indiana
I have for sale a 71 dart roller for sale. Has 8 3/4 with 3.23 posi with ladder bars and coil overs. I just installed as of yesterday a brand new disc brake conversion kit from Dr. Diff. Has all new inner and outer tie rods with new ajusting sleeves. Also has brand new oem upper control arms with new ball joints and bushings. Has new lower ball joints also. Has new master cylinder and all new steel brake lines and new front brake hoses. Has dr. diff proportioning valve for rear brakes. Also has a ratchet shifter and racing seat. Has new KYB shocks in front. Also as of today I just bought a set of 15x7 cop wheels and put new 205/60/15 yokohoma tires on front. The rear still has the small bolt pattern and not the cop wheels on it. Pic does not show cop wheels on front either as I just installed today. As you know with the doc diff brake kit it has new spindles , new calipers , new brake pads, new dust shields , new bearings. The inside of car is bare, meaning no interior except for racing seat. It does come with the bows for headliner, seat belts, sun visors kick panels. . Drivers side floor board would need repaired or replaced. Car has flat bottom trunk with a fuel cell. he car is very solid but paint is ugly. On each side of car where it had the big 3 inch body trim you can see where it was attached to the side of car by weld or rivets from factory. Whoever tried to fix it did a bad job. Im sure Im forgetting things and I need to post pics but didnt take any tonight. Underneath car is as solid as it gets. Also car has older hedmann headers. Dash is present but has bad pad as usually. I wont give car away. Few other things car is original blue and VIN # is LH23G1R154061. Fender tag is on car but I forgot to write it down ... 2500. Not center section Im selling it seperate. Its a sure grip with 489 case 3.23 gears
http://s1223.beta.photobucket.com/us...uda78/library/. my avatar is the car also
