71 Dart, What master cylinder
65Vart
Waterdown, Ontario
I need to replace the master cylinder on my 71 Swinger, KH front power disc brake, rear drums. Does anyone have a part number or a recommendation ? Doesn’t have to be OEM , stock replacement is fine.
If you buy from any parts store they will only have Cardone or similar that they sell as disc/drum master cylinders but in reality are just drum masters that look like this picture. This is what you need: https://www.partsgeek.com/nydr2k8-dodge-dart-brake-master-cylinder.html?
Look at a 73 Duster disc drum master. Thats about as generic as can be.
If you buy from any parts store they will only have Cardone or similar that they sell as disc/drum master cylinders but in reality are just drum masters that look like this picture. This is what you need: 1971-1976 Dodge Dart Brake Master Cylinder - Replacement 912-174 - PartsGeek.com
Thanks, that link lists manual brakes only, is the power brake master different ?
I found a casting/pt number on the existing MC which is 3280151 . Any ideas?
I can’t find a cross reference.
71 manual Disc and rear drum. I have not found the correct casting number for the master cylinder. This as been a big debate
