71 Demon Dash Pad?
Has anyone used a dash pad from BE&A? They are quite a bit cheaper than other suppliers. Curious about the quality. Thanks Warren
Any particular reason that you 'reported' your own post? :rofl: :poke:
Call them to check as lots of things on their website are outdated on availability and pricing.
This has been mentioned before but , in case you missed it, make sure the replacement pad has a metal core.
The plastic core is garbage.
Also, some of the new metal core dash pads are made with a lighter gauge metal so will bend /twist easier.
Best option, in my opinion, is to recover the original.
Just Dashes do a fantastic job of this but aren't cheap.
Fwiw I recovered the dash pad on my 62 Dart, cut the cracks out, spray foam in the cracks, sand smooth, inexpensive vinyl from a craft store, done.
Vinyl was fairly thick, and stretched nicely.
