For a 4-speed to 904 conversion.
Take the 4-speed stuff out and sell it to me.
Bolt a auto flex plate to the crank, make sure it is for a 904, there is different diameter on 727's it takes shorter bolts than the 4-speed.
As mentioned before the drive shafts are different lengths, maybe yoke size, and is different from which rear end you have.
Most likely you will be running a floor shift for the auto, so I recommend buying a locker kick down cable, less headaches.
You can just shove the 4-speed petal to the floor, or if you really want the auto petals I think I have two in my barn.
