[SOLD] 71 Dodge Dart Swinger
csingle5
ok
I have owned this car since 1993. 318 auto (904), air, ps,(original pump with dart pressure rating) and power drum brakes (all brake parts new). 742 case single track 8.75 new drive shaft, main leafs are thicker than original (I had them special built), stock sway bar in front, torsion bars are 383 mopar, power steering works like a firm feel I doubled the reaction springs when I rebuilt it. I installed a firm feel sector shaft support, and p.s. oil cooler. kyb at all corners. Engine, and trans are original to the car, .030 over, cast flat top, moly rings, .030 off the deck, balanced, stock mopar magnum heads, melling 360 dual exhaust cam(not the 340 cam) china air gap intake with a 625 demon plastic bowl. Griffin 2 row 1 inch radiator no tank cooler, trans cooler is b&m stacked plate. Passing gear made to work with carb, and the part throttle kick down works, 71 first year for that. Tf1 shift kit, all tranny parts new except I reused the original torque converter. new mufflers and all pipes. Door jambs are painted, under the hood is painted. I also have the paint for it. Tulsa, OK I can send more pictures if needed.
Asking $11,000
