Wizard
Will a 72 or 73-74 duster fenders fit a 71 duster? What are the differences? is the outside of fender of 72-74 same style as 71. Want it to look like a stock 71 duster. What interchanges?
I think the size of the marker light changes.
yes, that is correct. Is there any difference in the out body lines or flares on the wheel well openings or the inside where it mounts to front of header panel/radiator area? Light housings?To add to that. I believe the early side marker lights are in the fender and the later ones are on the outside of the fender.
Can you modify the 71 grille to bolt on?Is a bolt on except for the grille and headlight bezel area, the 70-72 grille and bezel will not fit properly.
There two different style fenders in 70 Early and late the headlight areas are different. Early take 69 headlight rim hardware late is the same hardware as all. The 71 fenders have holes in the fascia for the hood pins. 72 are the same as late 70 except for the marker lights 70-71 are flush mount markers 72 and later up to 76 take the same style they are plastic that just need holes in the fender there is no recessed lip.
73-76 are all the same what they are missing that is on 70-72 is the upper grille support mounts. Other then these items mentioned they all have the same body lines and wheel openings and fit from 70-76. The most significant difference is the upper grille support mount brackets for the 70-72 grille header.
