[SOLD] 71 duster project
rick hughes
71dusterdude
wv
Rating - 66.7%
2   1   0
71 duster(non h code) project that needs to be assembled must sell!
The engine is a 71 340 block .030 over fresh bore,new eagle rods,trw flat top Pistons,new rings,bearings,gaskets,oil pan,pickup,oil pump,cam bearins,freeze plugs,prw roller rockers,edelbrock aluminum heads fresh with 2.05-1.60 Manley severe duty valves,fresh 10/10 steel crank,new head studs,windage tray,new mopar m1 intake,new fabbed aluminum valve covers,new water pump,new alternator,new billet pullies,new ceramic coat headers,Hughes solid lift cam 579-582 lift 256-260@ .050 new lifters
The trans is a 4 speed that has been rebuilt (fresh) have all 4 speed linkage,column,rebuilt heavy duty pedal assembly,new pedal pads,new flywheel,factory bellhousing,factory hurst shifter with re chromed stick,new reproduction wood shift ball,cutch fork boot,
The rear is a factory a body 8.75 with new big bolt pattern axles,seals,bearings,all new brakes,brake lines,489 case with new strange spool with new 4.10 gears,new wheel cylinders,springs have been moved under frame rails with mopar relocation kit
Car has new paint,new carpet,window clips,weatherstrip,windshield rubber,rear glass rubber,340 stripe kit,tail panel stripe kit,new ladder stripe, new dual hood scoops, has sharkstooth grille,new headliner,headliner clips,mopar battery cables,new mini starter, new champion aluminum radiator,new gas tank,new 3/8 sending unit, new 3/8 fuel line,new trunk divider,new trunk mat, new side marker lenses,rally mirrors, new gull wing,all new front suspension, new front disc brakes,rotors,calipers,hoses,pads, bearings,strut rod bushings,new ball joints,idler arm,pitman arm,inner and outer tie rods, new addco 1 1/8 front swaybar,new door sill plates,new inner door handles,new outer door handles,new window cranks,new pentastar,new master cylinder,new brake lines,new steering coupler rebuild kit,new batterytray,new torsion bar seals and clips,new jegs lift bars, new weld wheels 15x10 and 15x4 new mickey Thompson 325/50-15 drag radials $11500 with wheels and tires $10500 without! I have over 13 grand in this car not counting any labor!! Located in charleston wv
