Jakeofalltrades
Boosted
Thanks, I'm hoping so!Cool build. It will be killer!
I almost went that route until I found this thing.That is nice! I used a Dorman freeze plug.
That looks good! It's the pro street clutch I think its called. Good for 450hp.Looks good Jake ! I like the silver on the bell .
Which Mcleod is that ?
I had Boise Muffler get my 3" exhaust installed yesterday . They did a great job ! Added a balance tube and welded the entire system .
Its much quieter now... more like sleeper I was hoping for.
View attachment 1715508667 View attachment 1715508668 View attachment 1715508669
I got the engine in for what I'm hoping is the last time. I ended up having to elongate out the holes in the transmission mount to try and get the engine as far forward as possible to keep the oil pump out of the crossmember mount. There is only about an .125" of metal left on the side of the mounting hole in the crossmember mount and it is still extremely close. The Schumacher headers for the most part slip right in. Both need modified as the passenger side hits the torsion bar and the drivers side interferes with the z-rod. The only other issue is the factory RB dipstick runs right into the steering box. I'll have to go with an aftermarket flexible option on that.
I modified the mount just like the directions. I think there are just too many variables for it to work perfectly for everyone. It's in and it should work.According to Schumacher instructions the drivers side motor mount pad needs to be notched for oil pump interference. This should help engine to sit level and in correct spot.
Any progress lately?
Reminds me a LOT of my project... here is the link when mine was at about your stage.. then the monkey wrench was thrown!
I know how that goes. Lots of lists!It's back in storage temporarily. Like Mike said we ended up moving to Japan. I'm working on a big parts list for when I get back.
