^^To add to the above^^ There are 3 lamp circuits in the rear of the car, and if equipped, one extra for the trunk lamp
1...Tail lamps and side markers are one circuit, and as mentioned above, the tail lamp filaments are in the same bulb as the stop - turn filament
2....Stop/ turn filament in the same bulb as the tail lamps
3....Reverse lamps in the clear section of the tail lamp housing.
HOW THIS WORKS. The key is the turn signal switch, which routes lamp power
1...With TS switch centered, switched brake lamp power comes from the pedal brake switch to the TS switch, and it connects that power to both rear stop/ turn filaments.
2....With TS switch on say, left turn, the TS switch leaves brake lamp power going to the right stop/ turn lamp filament, and of course routes the flasher power to the front and rear turn signal filaments.
3...In hazard, the hazard switch routes power from the hazard flasher to all four lamps.
What goes in TS switch:
IN:
A: turn signal flasher power, only with key "on"
B: Switched brake power from the pedal switch
C: Hazard flasher power on all the time
WHAT comes out:
1...Left front turn signal filament
2...Right front turn signal filament
3...Left rear stop/ turn filament
4...Right rear stop / turn filament
IN:
WHAT comes out:
