Mojoluv
Original H code car. Set up as a race car but uncut. Has R-block 340 with Brodix heads and the best parts money can buy. Engine is listed in the Mechanical Section on the board here separately. Fresh 904 with all A&A internals. PTC converter. 8.75 with 5.13 spool and Moser axles. Ladder bar/coil over suspension. Wilwood front brakes and all new front end. Triangle Engineering cell. Fiberglass hood and front bumper. This is a very highly optioned 340 Demon. Original Ralley Red car with black vinyl top and stripes. This car did not come with a wing and the wing in the pics will be removed. I have new weatherstripping and stripe kit that come with the car. New tires on the front and good slicks on the rear. I dont have the door panels. The body is very solid on the car. There has been some work done on the quarters years ago. Quarter extensions are perfect and so is the trunk pan, floors and rails. PM me for any additional info. Serious only! $12,500 You couldnt build the engine for that! Clear title in hand.
