ro23dart
So i have a couple of problems, probably not related but both electrical. The first is that my dash seems to be playing the juice harp every minute or so. I get a metallic "thung" that seems to be coming from the wiper switch. If its not it is close by, i can feel it strongly when i'm touching the wiper switch. This car is supposed to have the 3 speed wipers, i'm not sure that the switch that is in it is for a 3 speed, or if they are even different switches.
The second problem is the lack of brake lights or hazards. Turn signals work fine. I checked the brake switch and it works, passes voltage to the white wire at the connector. From there i have continuity from the other side of the connector to the white wire on the turn signal switch and no short. If i plug the connectors up though i get no voltage at the switch and i have continuity to ground. Short at a bulb maybe?
Any help or direction you guys could provide would be greatly appreciated, i'm a little tired so i probably missed something obvious.
