72 Demon questions
Hadahemi
Illinois
I recently bought a 72 Demon 340 , 727, 8 3/4SG, that will need some body work. Are the front fenders the same as a dart? If so, what years will fit? How about the doors and grille?
72 fenders are 1 year only, same with the grill, 72 Dart is the same, the other years will bolt on but there's differences, the 70-71 turn signal openings are different, the73 & up is a different fender all together but will bolt on if you were to use the same year grill and hood.
Ryan
aren't the Demon wheel lips differant like the Duster where they flair out instead of staying flush? the doors should be the same as a Duster.
Correct doors are 70-72 Duster or Demon.
No vent window recess in top edge of skin and the metal door tops.
