I just bought my first A-body. It's a 68 Dart GT convertible. It has drum brakes and I would like to convert to discs. I found a complete 72 disc setup(V8 K-member, LCA's, spindles, rotors, calipers, UCA's, swaybar and manual steering box) I know this is the small bolt pattern. Will this entire setup directly bolt in the 68? Would it change the front track width? Would I need a longer steering column? Other then a disc brake master and prop valve, what would I need?
Or...should I just hold out for a 73+ setup?
