72 Dodge dart Pro Street
maddart
Rating - 0%
0   0   0
1972 Dodge Dart-360 Magnum crate motor, 727 Trans with TCI 2800 Stall,Reverse manual shift valve body with trans cooler and trans temp gauge. 8.75 posi rear end with Richmond 4:30 rear gears,Moser axles and pinion snubber. Superstock springs Comp engineering adjustable rear shocks,newer front bushings. 10Gal. fuel cell with electric fuel pump/Fram filter set-up in trunk with Earls fuel lines/pressure gauge and regulator feeding a Holley 750 Demon carb. MSD ignition system,polished pulleys,fan, 1-wire chrome altenator. Hooker headers,2.5" exhaust,Edelbrock intake,Roller lifters/rockers,Painless wiring with rocker switches Battery and cutoff are mounted in trunk,All autometer gauges-mounted in dash Tach/shift light,summit racing seats with 5-point harness,B&M hammer shifter,centerline wheels 4.5" front/8" rear, P.S. 11" front disc brakes, kenwood stereo, electric fan, rechromed door handles/bumpers, newer vinyl top/headliner. Frame is tied. 6-Pak fiberglass lift off hood.Rear spoiler
Original hemi orange car from california.
Has heater/wipers deleted
Car was built right, Runs great, Drives awsome, and is very quick. 773-580-5477 $10,800
No Track time since ive owned it. Ran 13.23 thru the quarter with the 3.55 gears, now has 4.30 gears and 8" 2800 stall convertor
