[SOLD] 72 Duster 340
Moparman1806
Central NC
72 340 Duster - numbers matching 340,727, a/c, bucket, console car.
The previous owner had the engine and trans rebuilt, then managed to smack a tree with the left front- slight damage to left front horn- nothing behind k frame. He then parked the car and let it sit until I purchased it.
The numbers matching 340 still turns, and is very clean under valve covers, trans fluid is like new yet.
I purchased the rear quarters, extensions, wheel houses from another member in Arizona, front fenders that are very workable, hood, valence and hood latch support from a parts car I purchased.
It does need front floors, rocker work, the rear metal that I purchased, I would also do trunk floor. Rear rails seem solid, torsion bar crossmember is ok, left front rail has a small area just in front of crossmember that is repairable without replacing. Upper control arm areas are good. I started stripping car, bagging, and tagging, but my body guy disappeared. I can’t do this stuff with my injury, so it is time to go.
The seats are surprisingly nice, dash pad nice, etc.. I have an extra passenger door, extra trunk lid, rechromed front bumper. I also purchased the proper thermoquad(6139s), have a good trap door air cleaner. I have a good broadcast sheet, but fender tag is shot. All the a/c stuff, pulleys, brackets are here.
Options are:
A/C, 3:23 sure grip, buckets, console, am/fm, rally’s , inside hood release, B5 blue, shark tooth
Clean Pa title in my name
$6000 or closest reasonable offer takes all mentioned. 18252 Tamaqua Pa
Motor turns, had it fired for about 5 seconds pouring gas down carb. It has been in garage since( about 15 months), as I started tearing it down for restoration. As I stated, my body guy took off, and I can’t do the work do to injury.
I had carpets, interior, fenders, all engine brackets off to pull engine/ trans.
I had someone throw carpets, seats, and different fenders on for sale thread.
Here are a few pics before it started to get torn down
Trunk- needs extensions, trunk floor fixable, but would replace for full blown resto
