Relays are installed one under the hood for my blue wire feeds and one under the dash piggy backing from my 12V keyed power to run the new autometer dash. One power wire direct from battery feeds the power to both relays. Ran wire and solder / crimped connections until I ran out of heat shrink tubing. Should have it back under power by the end of the weekend if the new gauges show up along with the distributor... Gotta get my layout work done on the gauges so I can get the plate made up!
