HawaiiDuster
Looking to sell my 72 Duster. Its a real 340/auto car and I have the original numbers block freshly machined, bored .030, tanked, and decked. Also have a 727 that needs rebuilt and also the original heads that need rebuilt. 8 3/4 rear with 3.91 sg and offset spring hangars, 8 pt cage. Put new front suspension parts on it years ago and was never put back on the road. New lca pivots, torsion adjusters, bushings, .990 torsions, reinforced lca's. Currently has tubular uca's with BBP spindles, no calipers or adapters at this time. Will swap in a KH set up if buyer prefers. Rear is still SBP. Front rims currently on car do not go with it. No factory gas tank, but have a 15 gal fuel cell that can go with it. Car has just over 60k miles on it and I've owned it for over 20 years. I'm the 3rd owner and have known this car since it was new. It's a bench seat car and was originally a column shift manual steering, but I changed the column to a floor shift style. Car is located in Las Vegas. $6500 Various other parts and even a truck can included for the right deal
