Paladin06
Hello All,
I'm about to replace the instrument cluster in my 72 340 Duster with a very nice piece sold to me by one of our members but I have some questions first.
First rule lets not assume what I took out of the car is correct. I've found a number of incorrect parts and replaced them.
OK, the old cluster I took out has some small differences and they are.
On the front there is a spare hole just covered with a black plate not used.
The rear there is a small, perhaps 1 inch long, 1/2 in diameter electrical component. It looks like a resistor or something. it has an electrical lead that plugs into a slot at the top of cluster with another piece.
The speedo housing has basically an oval shape. Markings on the rear are 4952275 & 04091 & 301705-1 & 301650-1.
OK, the new cluster I want to put in.
No spare hole on the front.
There is no small, perhaps 1 inch long, 1/2 in diameter electrical component.
The speedo housing has flat surfaces. Markings on the rear are 2984395 & 04091 & 300480-1 & 301304-1.
OK, which is correct or will both work?
