GoldDuster340
I am having a power and starting problem with my 72 duster 340 when i turn the key i get nothing? battery is good 12v+ so that is good all grounds are clean 12 volts at coil when key is turned I have a complete factory wiring manual went through everything every wire from dash to engine compartment all perfect if i jump the relay the starter solenoid does click? any suggestions?
Not sure whats wrong.....
