[Found!] 7260 slip yoke
duster360
Alabama
Looking for a 29-30 slip yoke for 727 or A833 trans. Length is 8" from center of ujoint hole to end of slip part.
I have one from a 727 but it measures just over 9 1/2" total length.
Ken
Edison, NJ
I wonder why some of them are different lengths? I will have to check on that and get back to you.
Not sure either but the splines are deep inside the part that goes into the trans so it can be cut to the length that you need.
How did you measure it? Total length from end to end or from center of ujoint hole to end of slip part?
That one may not work. Mine are 1 1/2" deep. If I cut the one you have down, that would put the splines on your 2" deep. Will have to pass, thanks for offering.
8”
1 1/2 in for threads
