727 behind 5.7
swifter
wis
Anyone have a 727 behind there 5.7????? if so what is needed to convert from 4 speed to 727?????? Thanks Steve
Some guys claim you don't need the shim depending on the MY of the trans case.
I'm going to find out fairly shortly if I'm one of them.
I bought the flex plate and spacer from XV. You also need a neutral balance converter to run the 727.
Aj
