dart540
727 big blk trans comes rebuilt with modified stock drum,15 new 1.400 springs and billet retainer,5-red racing clutches,steels,modified stock rear clutch drum with 4-red racing clutches,steels,steel spacer ring,modified piston,new spring,CRT red racing KD Band,4.2 lever,HD Band strut CRT red racing reverse band,bolt in sprag,lightened sun gear,rear clutch,rear drum,4-pinion alum frt planets,3-pinion alum rear planet,sonnax red billet front servo,billet rear servo,acc.blocked,deep MP steel pan,new pump gears,babbitt front pump bushing,teflon sealing rings,new gasket,seals,pump blocked and vent moved to rear.Turbo Action RMVB with CRT special spring to increase line pressure.
$1575 free shipping PM for pics and details
Thanks FABO for ad space
