Hello ALL!!!
Here's the issue, '69 Dart BB /440. Start her up let her warm up, Sometimes not ALL the time, She will act like she's in NEUTRAL or PARK WHEN IN DRIVE or LOW GEAR??
(MILD SHIFT KIT- HURST HIS/HERS DUAL GATE SHIFTER) I usually shift it all the time,
Then after a while its fine! FLUID IS FINE ( COLD/HOT neutral,park) I just need her to last till
4 Speed goes back in but don't wanna BURN IT!!
I WAS THINKING FRONT PUMP??? only 5-6 K SINCE REBUILD!!!
A THANK YOU IN ADVACE AND HAPPY ST. PADDYS DAY TO ALL!!!! EVEN IF YOUR NOT IRISH
OR IRISH DESCENT!!
Thanks,
Mitch
OR IRISH DESCENT!!
Thanks,
Mitch
