Muscley MOPAR
anyone no if theres any difference in a big block 727 converter compared to a small block 727 converter
..............Very well put fishy68.................kim............
Yup, except for the brain fart about the 18 spine being in the "'67 or newer" transmissions. I knew you meant '67 or older but others might not. Don't worry, I get many more brain (and other type) farts as I get older too! Oh, and there are two different bolt patterns for the converter bolts on the factory stuff too so you may have to swap flex plates to go from the large diameter converter to the small and vice versa...............Very well put fishy68.................kim............
