ClassicSnap
Evening all,
I've never done a change of a governor and was wondering if I can do this with the trans still in the car. From what I've read, I remove the tailhousing, rotate the governor housing so I can remove the clips, remove the governor, insert new one, and then put everything back in reverse..i know there's some steps in between like remove the clip so you can slide the tailhousing off etc...just need to know if it can all be done while still attached. Seen plenty of videos and read articles of it being done while the trans is removed.
Thanks in advance for any help, tips and advice given.
