vwmoparguy
Hi everyone.
I put a built up 727 into my 65 Dart Gt. It has the factory floor shifter. I really would like to keep the stock shifter if possible.
I bought a 5 foot cable and bracket / shift lever kit from B&M.
The problem is the trans won't get all of the gears using the shifter. If I pull the shifter down into low, it hasn't even engage "drive" yet. Park on the shifter is park on the trans, but everything after that is wrong. I tried the original lever too (much longer than the B&M).
I truly believe that I need to either shorten the lever or drill a hole for the cable closer to the pivot point.
I see Imperials kit and it has a much shorter arm. I would gladly buy it but my biggest problem is time. I have a show Saturday morning.
Does anyone know what the distance should be or does anyone have an Imperial arm they can measure for me?
